Lifter tap??
The level of pressure for any particular lifter on the other hand is a function of the level of force with which the oil arrives at the lifter divided by the area over which the pressure is to be distributed. To the extent a particular lifter has excess clearance the effective oil pressure (at the lifter) would be reduced as it is spent filling the excess clearance and filling the lifter.
So, to the extent an engine had one more lifters with excess clearance, the level of pressure indicated on the gauge would be slightly less (e.g. 48 pounds) than the same engine would have with no lifter bores with excess clearance (e.g. 50 pounds). But the pressure gauge alone would not indicate the presence of excess clearance in single lifter bore, or bearing for that matter.
If you already have relatively healthy oil pressure, will a little excess clearance of a couple tenths really have a profound enough affect to cause a noticeable tick or tap? I would think you would already be seeing relatively low oil pressure for the difference between the pressure at the lifter and pressure at the sensor to hurt lifter operation.
As to how much excess clearance could reduce the oil pressure to the individual oversize lifter bore, I don't know, but I could envision it cutting the pressure in half. The oil will obviously flow to the area with the least resistance, but I don't know the relative resistance of the lifter internal chamber vs that of the external clearance.
Clearly if all 16 lifter bores are over size the pressure will be significantly affected and readily apparent at the sensor.
Lifter noise can be caused from many different issues within the lifter itself. As Kip mentioned, lifter tolerances are within .00001", which leaves minimal room for error. Theoretically a lifter should be able to stay "pumped up" even with low oil pressures. We've tested our stuff at idle with 8psi and 300* oil temperatures, for thousands of hours. This is pure hell on lifters, mostly the roller bearings, but they will survive.
The problem with most lifters is they're batch produced and use the entire tolerance window. This allows the highest percentage of parts to get through (pass) the equipment making them. When you start throwing heavy spring pressures and radical camshaft profiles at these batch produced parts, things can make noise and potentially fail. This happens because the hydraulic function of the lifter can't keep up. Lifter to bore clearance does play some roll, but even with .0025"-.003" clearance the lifter should still have enough oil available to function. We typically see a 5-10psi drop for every .001" extra clearance in all 16 bores. The real problem is when you don't have enough clearance. Ideally you want .0015" +/- .0005" clearance.
The preload should reflect the internals of the lifters themselves, and should be specified by the manufacture. The plunger inside of the lifter body needs to be in the correct position for oil to fill the chambers properly, providing the best performance while staying quiet. If one lifter is making more noise than the others, and requires more or less preload....9 times out of 10 it's because of a taper inside the lifter body.
See you Monday Kip!
