Torque spec for Tella-Yellow roller rockers?
Old Apr 25, 2014 | 08:34 AM
robertbartsch1's Avatar
Default Torque spec for Tella-Yellow roller rockers?
...tearing down the top of my engine now.... I need the torque reading for these..
I believe these were the only bolts on top of the motor that use lock-tight on the threads; right?
If a valve spring retainer was tearing up, would you see this without removing the rockers? There are NO busted metal pieces in either head and everything looks OK before, I remove the rockers....?????
Thx...
Old Apr 25, 2014 | 08:41 AM
KCS's Avatar
KCS
Moderator
Never heard of that brand before, but the bolts should still be 22-25ft-lbs.
Old Apr 25, 2014 | 08:47 AM
thanks...
Do you use lock-tight on these bolts?
Old Apr 25, 2014 | 12:21 PM
Russ K's Avatar
Rocker arm torque is 22 ft lbs, don't try 25 ft lbs as your going to strip the threads in the head. I use Permatex anaerobic gasket maker on the intake rocker bolts if the cylinder heads are ported.
Russ Kemp
Old Apr 25, 2014 | 06:05 PM
vettenuts's Avatar
Remove them in the firing order as well, this helps keep the load off of the threads in the aluminum head.
Old Apr 25, 2014 | 06:09 PM
KCS's Avatar
KCS
Moderator
Originally Posted by robertbartsch1
thanks...
Nope. Usually antisieze, or thread sealer for the ported heads, then 22-25ft-lbs depending on the bolt.
