need some help...checking pushrods LS6
Old Apr 26, 2014 | 11:25 AM
93civEJ1's Avatar
Cyl 2 at tdc measured 9 turns with the tool. I'm puzzled here.
Old Apr 26, 2014 | 11:36 AM
Darkman's Avatar
Well there are several things that can cause the variance, some mechanical and some having to do with method of measurement. The valves could differ if there was a valve job done in the past where the amount of grinding/lapping done varied. The method is tricky because used lifters don't always have enough internal spring pressure left to work with the adjustable pushrod consistently.
Based on the measurements you have taken, if I had to get pushrods today, I would put in 7.350 pushrods. This will result in a preload of 0.0375" to 0.1125". The actual range may be smaller depending on error in the measurement. Others may have a different opinion.
Old Apr 26, 2014 | 11:39 AM
93civEJ1's Avatar
Put 1 an 6 back at tdc. Measured 1 intake again. 8 3/4 turn again. Why do my numbers differen so much on each cylinder. I dunno what to buy.
Old Apr 26, 2014 | 11:53 AM
93civEJ1's Avatar
Ok using the torque method on intake valve with cyl one at tdc I got right before 2 full turns for 22ft lbs. this was with stock ls6 pushrod from 01 z06. I think they are 7.4
Old Apr 26, 2014 | 12:10 PM
93civEJ1's Avatar
thoughts? my local store closes at 3 and I am still puzzled as I have gotten 3 different measurements on 3 different cylinders, and not sure if i did the EO/IC method properly..but i marked the bolt and counted the turns.
Old Apr 26, 2014 | 12:34 PM
93civEJ1's Avatar
im not sure how u got those preloads...cause if I take 7.35 and subtract my 0 lash measurements i get from .025 all the way to .1 preloads.
Old Apr 26, 2014 | 01:07 PM
93civEJ1's Avatar
well, i wont be getting the car done this weekend it looks like. I know 7.35 was suggested, I just dont feel comfortable just getting something and throwing it in just to meet my deadline. The store closes in 55 mins and I am puzzled as all get out from my varying measurements. I cant find anything online at all of others having issues with measuring and getting different results for different cylinders.
Old Apr 26, 2014 | 01:32 PM
93civEJ1's Avatar
ok wait...i just found this...so is with the crank and cam gear dots lined up (cam dot at 6pm, crank gear at 12), is this not TDC compression firing stroke?
If not, I may have been measuring wrong. is that the case?
https://ls1tech.com/forums/generatio...dot-1-tdc.html
Darkman's Avatar
Good call. Wait until you are comfortable with your results.
Old Apr 26, 2014 | 01:38 PM
93civEJ1's Avatar
ok im having more thoughts now...when I lined up my dots (cam dot to crank dot, I did not think to check if the crank was actually at 1 cylinder of the compression or the exhaust stroke...i bet i need to recheck that.
Edit..nevermind..brain fart...when I lined them up I had no chain on..so intake / exhaust stroke wouldnt have mattered...it would have still been TDC.
Ok yeah im still puzzled on my measurements now.
Old Apr 26, 2014 | 02:09 PM
93civEJ1's Avatar
Ok I think I am maybe on to something. Im not sure if I measured cylinder 1 at TDC compression or exhaust stroke...How can I figure that out? So I would measure cylinder one and six at TDC...but how do I know which is a compression and which is at exhaust stroke or does this matter when measuring the pushrod length?
Old Apr 26, 2014 | 02:30 PM
  #32
93civEJ1's Avatar
Ok. I just found this. Using this I will redo my measurements and see what I get as I was measuring each cylinders one being at compression and one being at exhaust stroke...could be the reason for my odd measurements:
Quote:
Originally Posted by Joseph
LSX Firing Order 1, 8, 7, 2, 6, 5, 4, 3
TDC Cyl. #1) Camshaft dot at 12:00 / Crankshaft dot at 12:00
TDC Cyl. #8) Camshaft dot at 1:30 / Crankshaft dot at 3:00
TDC Cyl. #7) Camshaft dot at 3:00 / Crankshaft dot at 6:00
TDC Cyl. #2) Camshaft dot at 4:30 / Crankshaft dot at 9:00
TDC Cyl. #6) Camshaft dot at 6:00 / Crankshaft dot at 12:00
TDC Cyl. #5) Camshaft dot at 7:30 / Crankshaft dot at 3:00
TDC Cyl. #4) Camshaft dot at 9:00 / Crankshaft dot at 6:00
TDC Cyl. #3) Camshaft dot at 10:30 / Crankshaft dot at 9:00
Old Apr 26, 2014 | 03:35 PM
  #33
93civEJ1's Avatar
Ok followed the above and made sure I was tdc compression stroke. Checked cyl 1 and 2. 10 1/4 turns worked well for exhaust. 10 1/2 on the intakes.
If I do 7.4 that will leave me with .075 and .087 preload. Think that will be ok?
Old Apr 26, 2014 | 03:42 PM
  #34
Darkman's Avatar
That should work.
Old Apr 26, 2014 | 03:52 PM
  #35
93civEJ1's Avatar
awesome...7.4's I will order. I am glad I got my stupidity figured out on what I was doing wrong.
Old Apr 28, 2014 | 07:25 AM
  #36
93civEJ1's Avatar
so, is this below the sequence to use when i lay the pushrods in and am tightening down the rocker arms??
From Service Manual
Rotate the crankshaft until the number one piston is at top dead center (TDC) of the compression stroke. In this position, cylinder number one rocker arms will be off lobe lift, and the crankshaft sprocket key will be at the 1:30 position. The engine firing order is 1,8,7,2,6,5,4,3. Cylinders 1,3,5, and 7 are left bank. Cylinders 2,4,6, and 8 are right bank.
With the engine in the number one firing position, tighten the following valve rocker arm bolts:
•Tighten the exhaust valve rocker arm bolts 1,2,7, and 8 to 30 Nm (22 ft. lbs.).
•Tighten the intake valve rocker arm bolts 1,3,4, and 5 to 30 Nm (22 ft. lbs.).
Rotate the crankshaft 360 degrees .
Tighten the following valve rocker arm bolts:
•Tighten the exhaust valve rocker arm bolts 3,4,5, and 6 to 30 Nm (22 ft. lbs.).
•Tighten the intake valve rocker arm bolts 2,6,7, and 8 to 30 Nm (22 ft. lbs.).
Install the valve rocker arm covers.
Old Apr 28, 2014 | 07:56 AM
  #37
Darkman's Avatar
Affirmative.
Old May 4, 2014 | 08:42 PM
  #38
Blown_Red_97z's Avatar
I'm having some issues here too and I'm not sure wtf is wrong with me. I have the timing cover back on so no referring back to the timing marks. I'm not sure where I want to be on cylinder one and tdc. Are you at tdc just after the exhaust valve closes? That's what I would think but not too sure
To measure the intake valve length I think I want to use the comp 7702 when the exhaust valve is about to open. Then to measure the exhaust pushrod length i should use the tool just past when the intake valve closed correct?
Not sure why this seems so complicated but I am definitely not getting the same
Old May 4, 2014 | 08:53 PM
  #39
93civEJ1's Avatar
I had my cover and stuff on too...i took it off and then followed the TDC mentioned above. cylinder one is TDC on compression when Crank is at 12 and Cam dot is at 12
....use this , it helped me resolve my measuring issues:
Old May 4, 2014 | 11:14 PM
  #40
Really can't take it back off already put back in the ati balancer and new crank bolt
