need some help...checking pushrods LS6
Old May 5, 2014 | 07:36 AM
  #41
93civEJ1's Avatar
Originally Posted by Blown_Red_97z
Really can't take it back off already put back in the ati balancer and new crank bolt
Then I think you may have a rougher time. My guess is you will have to watch your valves, and find TDC by seeing at what point the piston is at in the stroke through the spark plug holes?
If the balancer and bolt is the only thing holding you back, it takes only a few mins to pull those off, and a bolt is what? a few bucks?
Guess it depends on what route you want to take.
Old May 5, 2014 | 10:24 AM
  #42
Blown_Red_97z's Avatar
yea i really dont want to take it back off, torque that bolt down is a mother effer.
So am i correct in the statement i made before? Do I want to check the pushrod length on the intake just as the exhaust valve is opening, and check the exhaust just as the intake valve on that cylinder is closing?
And which tdc do i want? on the compression stroke? which would be when it reaches the top after the intake valve closes.
Technically dont you have tdc on compression and on the exhaust?
Intake, compression, fire, exhaust. So in one cycle it hits tdc twice....
