what is the best camshaft
2.did any one tried the c1 cam shaft 221/221/558/558/112?
3.what about if i will use the c1 cam shaft and 410 richmond dif. together, did any one tried that, what i think is that the car will not move in 1st gear or 2nd gear coz it will burn out alot!!!!
any advice????????????
2. the C1 cam is 222/566/112, u listed the old T1 cam
3. stick or auto??
On #3, (he has an M6, Matt) if you have enough tire and enough track, you can certainly hook....but then the days of your stock rearend are few. If you wanna launch hard then start saving $$$ for a better rearend.
The noises that would come out of that rear when launching hard would make me pale.
I had a few "Sonic Booms" come out of there after a decent hook, and also had tons of grinding noises under hard acceleration in 1st or 2nd gear.
The strong low end of a T1 or C1 plus 4.10's in a 10 bolt = tow truck.
My rear never grenaded 'cause I switched to a peakier cam, but I'm sure a C1 with my current 9" would be loads of fun for around town bursts.
