I have had it with this squeal!!!!!!!
Old Apr 28, 2014 | 05:10 PM
Russ K's Avatar
Your PCV hoses are swapped. The hose from the valley pan goes to the port on the intake manifold, and the hose from the valve cover goes to the throttle body.
Russ Kemp
Old Apr 28, 2014 | 05:53 PM
Dr.Goat's Avatar
Yea I know, we never put them back since they are pretty much doing the same thing.
Old Apr 28, 2014 | 05:59 PM
BadBirdyWS6's Avatar
I had a squeal similar to that and it ended up being a bad motor mount putting the belt in a bind. Replaced motor mounts and it was gone
Old Apr 28, 2014 | 06:36 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Originally Posted by Russ K
Your PCV hoses are swapped. The hose from the valley pan goes to the port on the intake manifold, and the hose from the valve cover goes to the throttle body.Russ Kemp
Get your hoses going where they belong. This could be causing the sound. I say this because the sound goes away when revved up-which changes the vacuum level. Stranger things have happened....
And no, these hoses don't do the same thing....
Old Apr 29, 2014 | 08:13 AM
gagliano7's Avatar
I would fix those hoses. If that doesn't work check and make sure you balancer isn't walking off the crank.
Old Apr 29, 2014 | 08:48 AM
truckdoug's Avatar
i had a similar noise, PS pulley wasnt seated onto the shaft all the way…like .100" or something at it sounded like hell.
good luck sorting it. its that little **** that drives me crazy.
burned piston? bummer. dropped a valve? "we'll redo the valvetrain with nice stuff now"
slightly irritating squeal? MOTHER OF F&^% CO%^ SU%%$#R!!!!!
Old Apr 29, 2014 | 08:58 PM
Dr.Goat's Avatar
I took both belts off, and still makes the squeal..
Old Apr 30, 2014 | 03:20 AM
billymgb1000's Avatar
it must be something to do with vacuum if it is still doing it with the belts off. let us know
Old Apr 30, 2014 | 08:29 AM
Paul Bell's Avatar
Did you perform this test with the hoses still wrong?
Old Apr 30, 2014 | 03:43 PM
Dr.Goat's Avatar
Yea we are swapping them around today and going to listen to it again.
Old Apr 30, 2014 | 05:48 PM
Dr.Goat's Avatar
It was because of those hoses.
Old Apr 30, 2014 | 06:03 PM
  #32
Paul Bell's Avatar
DOH!
Old Apr 30, 2014 | 09:02 PM
  #33
Dr.Goat's Avatar
Yea...well at least the noise is gone. The car has all new pullies and gatorbacks so, preventative maintenance I guess.
Old Apr 30, 2014 | 11:06 PM
  #34
Paul Bell's Avatar
Glad you found the problem. Now go cruising!
Old May 1, 2014 | 06:58 AM
  #35
That's awesome goat aren't these forums great
Old May 1, 2014 | 03:10 PM
  #36
Dr.Goat's Avatar
Yep glad it's fixed before I go to the dyno.
