I have had it with this squeal!!!!!!!
Old Apr 27, 2014 | 07:27 PM
Dr.Goat's Avatar
Default I have had it with this squeal!!!!!!!
Ok, so I have this squeal that only appears when my car hits operating temperature. We replaced all the pullies and belts on engine. I have depressed my clutch and what have you to see if it was the throwout bearing, but thats not the case. When I rev the car up it goes away, or if its under load it goes away. Wth is this! Here is a video of the sound. Changed oil and found nothing in old oil or filter
Old Apr 27, 2014 | 07:38 PM
Darkman's Avatar
Under what circumstances did the noise start - that is, did you change anything, or did it just arrive one day?
Old Apr 27, 2014 | 07:48 PM
Dr.Goat's Avatar
We drove over to my friends one day and we put that fast 90 on then randomly after operating temp reached that squeal appeared. No funky idle problems. We checked for leaks around there, and found nothing. We also sprayed break cleaner to see if engine would rev from a leak. We tried turing ac on and off to see if that changed anything. But nothing. Clutch doesn't affect the sound. If it is revd or under load it goes away. Replaced both belts and idlers and tensioners....
Old Apr 27, 2014 | 08:24 PM
Dr.Goat's Avatar
Vacuum leak from fast 90?? It did it after we installed it. Car never made that noise before. After we installed it and car hit operating temp, it started. Maybe a gasket wwas bad??
Old Apr 27, 2014 | 08:35 PM
Darkman's Avatar
It is possible, but it does not sound like a vacuum leak to me. Sometimes a different part (the intake) creates interference with something up front - a pulley or belt, or even a radiator fan. Can we rule out power steering - the quality and quantity of fluid?
Old Apr 27, 2014 | 09:03 PM
Dr.Goat's Avatar
I am using the recommend oe fluid. If you rotate the wheel, it does not change sound. Unless something else could cause the sound to come from that area??
Old Apr 27, 2014 | 10:18 PM
jmargo's Avatar
Does it make the sound with the belts removed ?
Old Apr 27, 2014 | 10:25 PM
Dr.Goat's Avatar
We haven't fired it up with belts removed at operating temp.
Old Apr 28, 2014 | 12:18 AM
Mike_hawk's Avatar
If it still squealing with the belts off maybe try running it with the cold air tube off, so just throttlebody>intake and see if it goes away. Maybe the new intake is causing a whistle at a certain rpm.
Old Apr 28, 2014 | 12:45 AM
RJDio's Avatar
I'd do the old shade tree method, put car on ramps, start up idle, grab a can of WD40 and spray anything turning and see if noise goes away for a minute or two.
Old Apr 28, 2014 | 06:47 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Old Apr 28, 2014 | 12:42 PM
jmargo's Avatar
Originally Posted by Paul Bell
Who knows...it may be internal.
I would get it to temp and remove the belt after the noise starts. Just don't run for much time as you wont be circulating any coolant.
Old Apr 28, 2014 | 01:36 PM
GMC5.3's Avatar
And the ac pulleys and belts were checked correct?
Old Apr 28, 2014 | 01:53 PM
JakeFusion's Avatar
Super Hulk Smash
Spray water on the belt. If it goes away, it's an alignment problem. Possibly the power steering pulley or balancer. Although, that happens as soon as you start the car.
Remove the belt from the A/C to make sure it's not coming from there. Remove the belt after the car has heated up. It will run fine for a few seconds to check for causes of the squeal.
Have you replaced both idler pullies?
Have you tried a Gatorback belt?
Old Apr 28, 2014 | 03:18 PM
Dr.Goat's Avatar
Already tried that, it was making that sound with just the tb as well.
Old Apr 28, 2014 | 03:20 PM
Dr.Goat's Avatar
Yep, and replaced.
Old Apr 28, 2014 | 03:21 PM
Dr.Goat's Avatar
I replaced both pullies, actually almost every pulley. I replaced with gates belts. I took the ac belt off did nothing to change the sound.
Old Apr 28, 2014 | 03:23 PM
Dr.Goat's Avatar
I posted it in here, because I was not sure if it may possibly be something internal related................
Old Apr 28, 2014 | 03:34 PM
JakeFusion's Avatar
Super Hulk Smash
Gates belts suck. My sister and I both had belt slip on our LS1s with them. Run the Gatorbacks. But if it's happening with no belt...
Old Apr 28, 2014 | 03:44 PM
Dr.Goat's Avatar
I had the sound with gatorbacks as well. That is what I had on car when it started. Also I replaced my gator serpintine the other day. It wasn't even a year old and had stretched.
