Rod identification
Old Apr 30, 2014 | 02:43 AM
Decadence75's Avatar
Default Rod identification
I pulled these pistons and rods out of an LQ4 that came from a wrecked '05 Silverado 2500. Can anyone definitively ID them as either pressed or floating? From the research I have done, they visually appear to be the pressed pin rods but I thought that all '05+ motors had floating pin rods? Thanks!
Old Apr 30, 2014 | 07:04 AM
A.R. Shale Targa's Avatar
Definitely press fit as they don't have retaining clips.
Old Apr 30, 2014 | 07:06 AM
KCS's Avatar
KCS
Moderator
Yep. Look like the old press fit style. No retaining clips in the pin boss means they're press fit.
Old Apr 30, 2014 | 07:08 AM
That is what I was thinking. Thanks for the affirmation guys. Unfortunately no one is after these rods so I might as well turn them into some type of furniture.
Old Apr 30, 2014 | 06:35 PM
RezinTexas's Avatar
I sold a set of those on ebay for $70.
Old Apr 30, 2014 | 06:37 PM
Thanks for the info. Was it rods only or with pistons like I have them?
Old May 1, 2014 | 05:14 PM
RezinTexas's Avatar
$70 was for the rods only. They are likely worth less with the OEM pistons still in place, someone still has to remove them.
Old May 4, 2014 | 07:44 PM
Isn't it pretty easy to separate them? I have an arbor press that I used for my trunion upgrade, would that work for it?
Old May 5, 2014 | 05:13 AM
RezinTexas's Avatar
here's how I did it, not sure if an arbor press would work or not.
Old May 5, 2014 | 05:19 AM
here's how I did it, not sure it an arbor press that would work or not.
That was the idea that I had for doing it but the more I think about it, the less likely it seems I will be able to do it with the armor press. I have maybe 5 inches of space in the press so I doubt I could get that worked out unless I maybe use stacked shallow sockets one at a time to press the pin out. I just hate to get a shop press for something like this. Although a shop press would probably help with the rear end rebuild I want to do sometime soon. And I think HFT has them on sale right now.
Old May 5, 2014 | 05:34 AM
Looks like HFT has the 20 ton on sale for 170 and I can get another 20% off that so if they have one in stock I might just go for that. I thought about the 12 but I don't know if that one would be sufficient for everything suspension and rear end related.
Old May 5, 2014 | 11:14 AM
RezinTexas's Avatar
I got the 20 ton unit at HF and have been pleased with it. I also use it when rebuilding pool pumps. It has a fully welded frame vs the 12 ton model has a bolted frame.
Old May 5, 2014 | 11:42 AM
Thanks for that extra info. That makes it worth the extra few bucks then.
