How does my camshaft look...
Old May 4, 2014 | 10:40 AM
Z28SLPCAMAROZ28's Avatar
Default How does my camshaft look...
Swapping my valley cover gasket, figured I'd post a picture of my camshaft as it looks like it has some wear to it. But after 139,000 miles, I expected this. Anyways how does it look? Normal for this mileage? Maybe swap in the near future?
Old May 4, 2014 | 10:45 AM
427zm's Avatar
With that mileage, it looks about right. The scuff on the left lobe is a little unusual, but again, it's got a fair amount of mileage on it. You need Heads and Cam now.
Old May 12, 2014 | 10:12 PM
Off topic from my original post but I don't feel like cluttering any other sections with a new thread, plus I wanted to bump this back up for further input on my cam condition. Anyways, recently I developed a slight oil leak (couple drops) only at startup. So while I had my intake manifold off for an LS6 swap, I decided to swap out my valley cover gasket since it's right there. Naturally I broke my OPSU as well so it was replaced. Well after startup I still have the same small leak. I figured it was probably the valley cover gasket because of the picture attached. PCV hose was replaced as well as mine broke. I replaced my valve cover gaskets also since I had the coils off for plugs and wires. Does anyone know anywhere else the leak could be coming from?
Old May 12, 2014 | 10:19 PM
JakeFusion's Avatar
Super Hulk Smash
My stock cam with 145k miles didn't look like that. Have you had any oiling issues?
Old May 12, 2014 | 10:30 PM
To my knowledge, no. However I got the car with 130,000 miles so what the previous owners did is an unknown.
Old May 13, 2014 | 01:14 PM
gagliano7's Avatar
Could be your cam sensor leaking the oil.
Old May 13, 2014 | 04:41 PM
Yeah, I'm hoping it's not the cam sensor because I wasn't aware there is a simple seal to replace. Everything is back together now so it'd really suck if it was it. I got degreaser and UV dye to finally find the source of it.
Any other input/opinions on the cam condition?
Thanks
