Cam choice for set up, opinions.
Set up
4.8 fresh rebuild, new rings and bearings, truck intake, 243's(will be milled), long tubes and this will be a nitrous motor. I really like the tick performance street heat stage 1. Super low overlap, nice exhaust duration and I'm digging the larger intake lift. Going into a 78 c10 and will be a weekend warrior, so drivability isn't a concern. Also please help with injector size info as well.
Since the engine is so small I'd run the LPE GT2-3 cam which would go nicely with a set of PSI 1511 beehives and NOS as well. 28.8 injectors would work for the power level assuming a wet kit and not a dry shot.
