LS6 Oil Pump Shims
Old May 6, 2014 | 06:57 AM
projectX's Avatar
Default LS6 Oil Pump Shims
Hey fellas,
Can anybody tell me what size shims I need to install the oil pump?
Thanks
Old May 6, 2014 | 02:57 PM
projectX's Avatar
Anyone?
Old May 6, 2014 | 04:54 PM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
Originally Posted by projectX
Hey fellas,
Thanks
The easiest way to do it is when you unscrew the cap that holds the spring, take the cap and put a nut or a few washers and fill the underside of the cap leaving just a little cup for the spring to sit in. I believe it's just a hair under 1/4".
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old May 6, 2014 | 05:19 PM
KCS's Avatar
KCS
Moderator
Hey fellas,
Thanks
If you're talking about shims to center the pump housing, I use .002" and/or .003" thick feeler gauges. In a pinch, regular old notebook paper works too...
Old May 6, 2014 | 05:53 PM
projectX's Avatar
Correct, those were the numbers I was looking for.
Thank you Sir
