What would cause this much damage?
In the photo, it looks like the bearing halves we removed from some of the caps. Half the thrust bearing looks to be in place.
Like I said, more info and pics would be interesting.
Once that issue was sorted out, I rebuilt the engine and it made over 700whp. No complaints after that.
The bluing of the main caps is from the crankshaft counterweights rubbing, but the thrust bearing, under normal operating conditions, prevents that from happening. The condition of the thrust bearing will give a better indication of what happened.
Apologies. You can't control the owner bolting the converter up.
Ron
I found out later he LET HIS KID DRIVE THE CAR(who is a member on this site)!. I lost over 5k on the mess. There wasn't too much I could do about EXCEPT next time I know better. NO test drives, no driving the car without me in it. If the shop doesn't like it TOO FKIN BAD!
I know a shop didn't do this mess and I can tell you WITHOUT A DOUBT that engine was built properly.
I've been doing this a long time, I can smell BULL **** a 10 mile's away!
