What would cause this much damage?
Old May 6, 2014 | 10:15 AM
blake2kz71's Avatar
Default What would cause this much damage?
2001 LS1 forged rod/piston, studded 241 heads, 11lbs D1 procharger, approximately 5k miles since rebuild. Looking for any likely scenarios that could possibly cause this.
Old May 6, 2014 | 11:21 AM
KCS's Avatar
KCS
Moderator
Damn, that block almost split in two!
What does the thrust bearing look like?
Old May 6, 2014 | 11:53 AM
MadFirehawk86's Avatar
Looks like crank walk to me, but ive never heard of that with an LS1. Something wasnt right with the rebuild....was the rotating assembly balanced?
Old May 6, 2014 | 12:19 PM
RezinTexas's Avatar
What do the rods look like?
Old May 6, 2014 | 02:34 PM
blake2kz71's Avatar
All the bearings were either spun or gaulded like it got pretty hot. Yes the assembly was balanced. Could the torque converter have balooned?
Old May 6, 2014 | 02:36 PM
blake2kz71's Avatar
I also thought it could have been an issue with the rebuild but after 5k miles?
Old May 6, 2014 | 02:50 PM
N20zuki's Avatar
Id like to see the thrust bearing, I would think that is the culprit.
Old May 6, 2014 | 02:56 PM
blake2kz71's Avatar
Maybe so but why is the big question. Long story short I was overseas, trying to sell the car, let a buddy drive it to a few people to look at and came home to this mess. Of course he claims it ran fine before he parked it.
Old May 6, 2014 | 03:17 PM
nm2769's Avatar
Holly crap man! That thing is split all the way up to the cam. Did it even have a thrust bearing installed? Sorry for your troubles.
Old May 6, 2014 | 03:43 PM
CHEVELLEPOSSE's Avatar
Bad rebuild
Old May 7, 2014 | 07:06 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Youch!
Looks like the crank had some severe fore/aft movement.
Assuming the engine ran fine for the 5,000 miles, and the fact that you were running 11 pounds of boost, I'd say the build was good but there was some extreme abuse of the engine.
Originally Posted by blake2kz71
...let a buddy drive it to a few people to look at and came home to this mess. Of course he claims it ran fine before he parked it.
Without a doubt, this is the cause of your busted engine.
Old May 7, 2014 | 08:40 AM
.boB's Avatar
No oil or no oil pressure. You can tell how hot it got, because the steel caps are blued.
Old May 7, 2014 | 09:23 AM
Paul Bell's Avatar
Good catch there, I didn't see it. Can't say I've ever seen main caps blued like that from heat. Some good friend, eh? It's one thing to beat an engine like that but way worse when he says ''it was fine when I parked it''.
OP, I'm curious, what was the oil's condition when you opened this up?
Old May 7, 2014 | 09:46 AM
racer8088's Avatar
The thrust bearing completely went out it looks like as you just can't have the counterweights hitting the main webbing any other way. The cracked block is also pretty weird. Who built this? An abusive driver can't really make something like this happen in general it had something wrong that ate the thrust bearing away completely. Must have had a trans or converter issue forcing the crank forward like people are saying. Could have been installation errors with the transmission side of things or something weird with the thrust bearing too.
FWIW I have seen that happen three times and of the people all three had had converter issues and one had an engine assembly issue too.
Old May 7, 2014 | 12:59 PM
CBM Motorsports's Avatar
We have seen stuff like this before. Most of the time it is transmission related. It looks like something from the back side of the crank was pushing the crank forward. I am with the other people saying its tq converter related.
Old May 7, 2014 | 05:46 PM
Paul Bell's Avatar
I'd agree with all that^.
But that engine certainly made a lot of noise and smoke (from the oil burning on them mains) for the "friend" driving it to not at least know something was amiss.
Old May 7, 2014 | 06:22 PM
KCS's Avatar
KCS
Moderator
Yeah, I would think the counterweights rubbing the main caps would make a ton of noise.
Old May 7, 2014 | 07:19 PM
Hardcoresoldier's Avatar
so this is an auto trans car? In a manual this is easy to cause by putting in the wrong pilot bearing....
Old May 7, 2014 | 08:31 PM
RonSSNova's Avatar
Any telltale signs on previous oil changes. The thrust wouldn't fail in one fell swoop.
I'd be more inclined to think it lost oil pressure and was continued to be driven like that.
BTW, you can see the thrust bearing. It's in the middle of the crank, not on the rear main.
Got more pics?
Ron
Old May 7, 2014 | 10:45 PM
RockinWs6's Avatar
Only one thing killed this engine..EXTREME ABUSE CAUSING THE TQ to balloon and fail.
Almost reminds me of the time I took my car to the trans shop and when I went to pick it up number 7 piston was in the exhaust.........BUT NO BODY KNEW ANYTHING ABOUT IT...........
