Can valvesprings slow car?
Old May 8, 2014 | 11:29 PM
RealLiveMD's Avatar
Default Can valvesprings slow car?
My cam has a .610 lift. I had comp .650 springs. I replaced with some prc .675 that I've had for two years. I lost 2 mph and a full second in the quarter. I really don't feel like changing these springs. I noticed a loose spark plug cable but think a cylinder would have dropped me more than 2 mph. Also I pulled the valve covers and don't see a broken spring. Any explanation?
Old May 9, 2014 | 12:44 AM
03EBZ06's Avatar
Might are very tight. I have not had a problem.
What is the install height? coil bind? compression rate for old and new springs??
2mph and 1 sec do not equate.
Old May 9, 2014 | 07:02 AM
RealLiveMD's Avatar
I'm not sure about the install height etc. I was told. That the. Tsp springs were a direct replacement. I now read that they have about 50 lbs more opening and closing pressure
Old May 9, 2014 | 12:05 PM
Sales@Tick's Avatar
How much usage did the PRC springs have?
Old May 9, 2014 | 12:15 PM
RealLiveMD's Avatar
prc springs are new
Old May 9, 2014 | 12:17 PM
Sales@Tick's Avatar
Adding spring pressure where it isn't needed can and will lose power.
That said, I don't see it losing 2mph and a full second.
The loose spark plug cable is most likely the culprit here.
