Lq4 build with 6.365 rods
Has anyone here run that long a rod? I bought them already to run and I was curious to see if anyone else has.
Thanks guys.
My setup so far
Lq4 block
Stock crankshaft
K1 6.365 rods
Wisco pro pistons
Thanks guys.
My setup so far
Lq4 block
Stock crankshaft
K1 6.365 rods
Wisco pro pistons
Super Hulk Smash
Why would you run that long of a rod on the stock crank? Are you trying to sustain more dwell at TDC?
You should still be able to have a pretty thick piston crown with those rods given the stock crank, but that's an interesting combo. I've seen 6.200" rods work well with 4" stroke combinations.
Did you have Wiseco cut the pistons for you with those rods spec'd?
