longer crank bolt?
And on a stock damper with the elastomeric rubber bonded between the outer & inner sections, 400 degrees might negatively affect the bond.
Get the right damper installer. Or make one up with a threaded rod, a nut, washers or a plate of some kind with plenty of grease on the threads and nut.
