How to Tighten Crank Bolt?
Old May 19, 2004 | 10:39 AM
Ed Blown Vert's Avatar
Originally Posted by Whistler
The ATI fastener is not a TTY bolt, it's standard grade 8 hardware, so it's reusable. Put red loctite on the threads and around the head where it meets the washer, then crank it in as tight as you can get it.
Thanks! Good to know.
Old May 20, 2004 | 10:23 AM
Haulin' SS's Avatar
I thought the instructions say to tighten to 40ftlbs. and then another 180 degree turn?
Old May 20, 2004 | 10:45 AM
I think it was 40 ft lbs, then another 1/3 turn.
Old May 20, 2004 | 06:44 PM
foff667's Avatar
LS1TECH Sponsor
fwiw i added the pic to the second pg of my head install if you want to see the tool i made
Old May 21, 2004 | 08:56 AM
ls1blown871's Avatar
When you put the pulley on, did you stay away from the oil pump and if so
how did you know???????
Old May 22, 2004 | 03:29 PM
WMSuperSport's Avatar
Default makeshift way to hold crank still
I jut ram a ratchet between the balancer and various accesories and it works with any tranny and costs nothing. Its easy, quick, and doesnt hurt anything. Hope this helps...
Old May 22, 2004 | 03:37 PM
Thanks, I was able to jam a scredriver in the flywheel and cranked down on the bolt.
