LS1 with Te-Rex Camshaft
Old May 30, 2014 | 02:13 AM
eng.BBC's Avatar
Default LS1 with Te-Rex Camshaft
Dear all ls1 tech participants i would like to be a member with your comity , hope to add some values to yours and gain from your experiences.
i would like to run a new project for drag race application 1/4 mile, ET 10 sec, i decide to run FOX body with LS1 stock bottom , heads,and Te-Rex cam shaft with A4 transmission and 4.56 rear end and 28 inch rear tiers
for the first time i use the Te-Rex camshaft i would like to Clarify certain points as following:
1- what are the recommended Valves spring for that Te-Rex camshaft?
2-What are the recommended Carb Intake for this application?
3- if you have more please feel free to share.
hope to hear from your experiences.
Old May 30, 2014 | 05:14 AM
35th SS's Avatar
dual springs
4k stall converter
Old May 30, 2014 | 09:44 AM
Nissan LS240's Avatar
I guess what heads you're using might be some needed info, but I'm using afr 8019 springs, on my afr 210 heads and ls7 lifters, been reving it to 7400 haven't had any issues so far
Old May 30, 2014 | 12:27 PM
Rise of the Phoenix's Avatar
I would check with Brian Tooley and use whichever of his springs he recommends.
Old May 30, 2014 | 01:00 PM
thunderstruck507's Avatar
if you are putting a carb intake on it, put a carb cam in it by calling a couple places and get something spec for your build rather than an off the shelf max effort cam meant for plastic low profile intakes
Old May 30, 2014 | 05:08 PM
garygnu's Avatar
agreed ^^^^. check out EPS cams ,or tick performance for the best cam . get some after market trunnion bearings .measure for proper push rod length when you get the cam installed .
Old Jun 2, 2014 | 10:14 AM
what they said ^^^^ is probably what you should do, I built my motor around the t rex cam, its definitely not a daily driver cam, as it feels sluggish when you're just trying to take off on a green light while trying to sneak past a cop, but full throttle and keeping it above 3500rpm after shifts it feels pretty good,
Old Jun 2, 2014 | 03:22 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I'd call Geoff at EPS and see what he says; he created that cam after all.
But, that can was made more on a "I bet you can't fit it in a 346" whim... There's much better cams out there, and he'll even tell you that.
Old Jun 2, 2014 | 03:31 PM
EPS makes an "off the shelf" single plane intake cam. I'd look into that as an option over the T-Rex.
http://www.engpwrsys.com/index.php?a...d&productId=12
Old Jun 3, 2014 | 08:59 AM
Sales@Tick's Avatar
T-Rex has IMO much too late of an intake valve close event for a carb style intake unless you want to turn it to the moon quite literally.
With a 6000rpm stall it would run it's cojones off though...
