Changing out Rod Bolts???
Can anyone offer some advice?
My formula is getting a new cam, heads, springs so I thought now would be a good time to change the rod bolts too.
I am doing all the work myself as far as installation, removal, etc. How hard is this? I have access to a lift, or a cherry picker if the engine needs to come out. Right now the intake, vavle gaskets, heads, and headers are off the car. I still need to pull my cam as well. Will I be better off pulling the engine out to do the cam and rod bolts, or just leave it in and work around everything?
Anyone have a write up on how to change them? TIA!
Rob
Rob
Rob
Rob
Rob
Rob
Changing rod bolts in an engine isn't the way to go nor have I heard anyone doing it that way. Generally, when changing rod bolts you resize the big end because the bolt doesn't just slide out, you have to knock it out.
Ever seen an ls1 rod bolt? Trending Topics
This is not grandpa's 350.... The LS1's use regular style bolts that thread in, not the old school rod bolts that have been used for the past 50 years.
As to changing them, just remove one at a time. The ARP's will require you to retorque them 3 times to get proper bolt strech. If you do it with the engine in the car, wear saftey glasses. I learned the hard way that oil is not meant to go into your eye. One small drop burns like a bitch!!
According to the 1998 Service Manual (Volume 3, p. 6-297) you can remove the oil pan (with a stock k member) without taking the engine out. Does anyone have any experience doing this?
