Out with the TSP 233/239, Clueless on what goes in.
#62
Brian Tooley .660's went in 1,000 miles ago in an attempt to correct the issue. They were installed at 1.78 initially. When the dyno showed no improvement Brian Tooley advised going to 1.75 installed height. The adjustment was made. New dyno showed no change. Brian then advised checking pr length. It was determined that the 7.375's that were in it were too long and creating too much preload on the lifters (for 10,000 miles or so). They were replaced with 7.350's per pr length check results. Car seems quieter and happier but no change on the dyno.
#66
Super Hulk Smash
Realize that it got worse over time. That was its first pull. Here are more after more mods. There are 2 later ones that are not showing here, where it hit 464 hp and then 471 rwhp. In both of those the float was even more pronounced.
If it's not valve float then what accounts for the damage to brand new valve seals and seats?
So, if it were me, I'd check the fuel and ignition system exhaustively. If they are working correctly, then I'd pull the heads and the cam, inspect the lifters and the cam lobes and see how they look. If they are damaged, then you know you had a system that was out of control and the lifter/pushrod combo would be the first thing I'd change and then I'd shim up the springs and swap the cam. If not, then you'll likely need to start over again. It's making good power, so the combo isn't crap.
#67
I am running the 230/238 cam you mentioned. It is paired with some 799s that have hand cuts to the intake side valve boss and removed rocker bosses, otherwise they have nothing but hit with sanding rolls to knock off the casting flash. Exhaust side had sanding rolls only. Milled .010".
Car ran a best of 11.67@115mph (best trap was 116mph) in 2000 DA on 1.72 60ft with it hitting the rev limit on the 2-3 shift. Car weighs ~3700lbs with me and fuel and has the front end of a brick.
Made 390rwhp through unlocked stall and closed cutouts, peak at 6300rpm but carried out pretty good. Based on previous runs with it locked I would say it would be around 410rwhp locked. Car has a 12bolt and a ridiculously heavy 3.5" chromoly driveshaft which is 56" long.
For reference, with a Comp XE lobe copy of the TR230/224 cam and stock heads the best it ran was 12.24@110.38 mph in similar DA. All other mods were the same.
#73
