Will LS7 lifter in LS1 work?
Old Jun 5, 2014 | 12:52 PM
KrpticZ's Avatar
Default Will LS7 lifter in LS1 work?
So I have to change lifters was wanting to upgrade and was thinking about switching to LS7 lifters. Will they work, if so do i need to do or get anything else to make them work? Currently this is a project car its also a daily driver. Eventually gonna go with LS6 heads, fast intake, lsr cam, upgrade fuel injectors, trans wise putting a trans go hd2 shift kit, bigger converter, and eventually change the rear end. Currently focused on the lifter issue though. The ticking issue is annoying and I hate the power loss. Any help or advice on this would be awesome especially certain specs for head types etc.
Old Jun 5, 2014 | 12:57 PM
conan's Avatar
LS7 lifters are the OEM replacements for all LS engines. So yes they will work, I would recommend getting LS2 lifter trays for the install.
Are you running a aftermarket cam currently ?
Old Jun 5, 2014 | 01:01 PM
KrpticZ's Avatar
Thanks Conan, no currently I'm not running a aftermarket cam. Will be eventually though.
Old Jun 5, 2014 | 02:30 PM
Sales@Tick's Avatar
I would forgo the LS7 lifters and go for a set of aftermarket lifters.
I have some very nice drop in aftermarket lifters that are less than 100 dollars more than LS7 lifters.
Old Jun 5, 2014 | 02:35 PM
KrpticZ's Avatar
Whats the range on them? I do go to the track on occassion and I have a lot of road fun as well. What kind of price are we looking at as well? I dont mind looking into them if they perform good and will work with the other stuff I have planned as well. I just dont want to have to do the work twice.
Old Jun 5, 2014 | 02:55 PM
KrpticZ's Avatar
Looked at your site and saw the many different options which ones were you talking about?
Old Jun 6, 2014 | 08:19 AM
Sales@Tick's Avatar
I prefer the Morel 5315. We sell them for 220 dollars shipped.
Old Jun 6, 2014 | 10:25 AM
KrpticZ's Avatar
Im probably gonna need a good cam as well I want something with a good lobe and decent power but will work with basically a stock setup for now what would you suggest for that? I figured if im having to change lifters and the engine is already have way broke down I might as well do the cam while I'm at it.
Old Jun 6, 2014 | 11:59 PM
ls1 1990 VN's Avatar
Good idea, but be aware of the extra parts & Dollars needed that go with a cam swap.
Old Jun 7, 2014 | 06:52 PM
Sales@Tick's Avatar
I see you're in Concord as well! We'd be glad to tune the car for you once you've installed the camshaft also. We're located in Mount Airy, about 80-90 minutes North of you.
As far as the camshaft is concerned you mentioned that this is a DD correct?
I prefer and so do most of my customers as well that overlap is kept minimal in DD applications for MPG and driving manners to stay as close to OEM as possible.
Old Jun 7, 2014 | 06:55 PM
"MAC"'s Avatar
Yes they will work i have LS7 lifters in my ls1
Old Jun 8, 2014 | 12:33 PM
KrpticZ's Avatar
I think I might just have to come down and visit you all. I'm constantly working 12-17 hour days so its really hard for me to get out though. If i had time I would probably do most the work myself unfortunately time wont allow me to and I can barely use my hand anymore due to young stupidity. I'm new to the area and all the help I can get is greatly appreciated. I'm on a bit of a budget at the moment though spent to much money moving down here from Virginia the last month. I'm sure I have heard your company mentioned several times though, and its all been good. I will be coming to visit when I get the time.
Old Jun 8, 2014 | 03:11 PM
NemesisC5's Avatar
For what reason do you prefer the Morel 5315's ?
Old Jun 8, 2014 | 05:09 PM
codyvette's Avatar
$$$ That is actually over twise what a set of LS7 lifters cost. I am not saying they aren't better but LS7 lifters will work fine.
Old Jun 8, 2014 | 05:15 PM
codyvette's Avatar
The tapping may not be lifter noise. If it changes when the motor warms it could be piston skirt slap at the bottom of the cylinder. If you go with a slightly aggressive cam the valvetrain noise may get louder even with all new parts. That's an LS for you. They make POWA though.
Old Jun 9, 2014 | 02:54 PM
c7monster's Avatar
just go with the ls7's
Old Jun 10, 2014 | 11:35 AM
KrpticZ's Avatar
So I think I'm gonna go ahead and go with the LS7's now I need a decent cam. Any suggestions? Basically stock.
Old Jun 10, 2014 | 11:55 AM
codyvette's Avatar
That's a debate that cam go on for ever but if you are mostly stock other wise, anything from 216/220-228/230 will make good power. Power curves will vary but they ate all a blast. Jegs has a couple of cams right now for $300. Good luck to you.
Old Jun 10, 2014 | 12:10 PM
KrpticZ's Avatar
I only have to drive 10 miles a day to work so gas mileage isnt an issue, I would like something with a good lobe, and decent power. I probably have more fun on the street than I do at the track since i constantly work 12-17 hour days. So I'm definitely looking for the street performance more than track.
Old Jun 11, 2014 | 06:43 AM
codyvette's Avatar
224/224 .585/.585 112lsa
Or Jegs has this cam for $300. I have one and it makes good power and chops it up pretty good at idle. PM me and I will send you and idle video through LT's, high flow cats, and a medium baffle Borla.
http://www.jegs.com/webapp/wcs/store...&storeId=10001
