New YT rocker failure
Old Jun 11, 2014 | 09:00 AM
99 2500's Avatar
Forgot to mention there is no needle bearings in the roller tip only a pin.
Old Jun 11, 2014 | 09:04 AM
vettenuts's Avatar
Originally Posted by 99 2500
I had the same type of failure on the new rockers, was only on one rocker.
Did you soak/prelube during installation?
Old Jun 11, 2014 | 09:13 AM
99 2500's Avatar
Sure did, I even felt the slight hitch in this particular roller but didn't really think anything of it.
Old Jun 11, 2014 | 09:21 AM
vettenuts's Avatar
How did you know it failed? Noise?
Old Jun 11, 2014 | 11:51 AM
99 2500's Avatar
I found the worn roller pin when I changed the engine oil and found needle bearings stuck to the magnet, they came from another rocker that had a broken cage.
Old Jun 11, 2014 | 11:54 AM
99 2500's Avatar
Forgot to attach picture of rocker with needle bearing failure.
Old Jun 11, 2014 | 12:04 PM
vettenuts's Avatar
Is that the same rocker? How many miles?
Old Jun 11, 2014 | 12:21 PM
99 2500's Avatar
Different rocker about 16,000 miles, was surprised I did't hear any odd noise. Yella Terra sent me two replacement rockers since only two were bad, running good since then and about 15000 miles since replacement.
Old Jun 11, 2014 | 12:58 PM
COSPEED2's Avatar
LS1Tech Sponsor
Usually if it is starved for oil you will either also get valvetrain/lifter noise OR hear a very loud rhythmic squeaking noise that wont go away. It is possible the feed hole at the back was not machined correctly.
Old Jun 11, 2014 | 05:15 PM
RonSSNova's Avatar
Info and photos are with the US rep and will be discussed with Australia this week.
Both Hinson ( supplier) and the YT rep have been very helpful.
We shall see what happens!
Ron
Old Jun 11, 2014 | 05:44 PM
miami993c297's Avatar
Ron
Waiting to read where that goes Ron...I am now worried with mine...
Christian.
Old Jun 11, 2014 | 06:25 PM
  #32
RonSSNova's Avatar
Thanks for chiming in. I have 4 like that.
I'll check the rest after I get them out.
Old Jun 11, 2014 | 07:01 PM
  #33
SSZ's Avatar
SSZ
Just to give fair warning on the Scorpions. My friend put a new set on his 99 vette. They were noisey right away. They came off right away also and he went back to the stockers. Just a heads up Ron if you were looking to go that route.
This sucks to read. Hope you get it resolved.
Old Jun 11, 2014 | 08:37 PM
  #34
RonSSNova's Avatar
Thanks. My supplier mentioned that no-one buys the Scorps.
Good thing I stumbled on this huh?
Ron
Old Jun 11, 2014 | 08:51 PM
  #35
ss performance's Avatar
I'm very concerned, I just purchased a set.
Old Jun 11, 2014 | 09:00 PM
  #36
COSPEED2's Avatar
LS1Tech Sponsor
No one in the ls market buys them because of the bad stigma. Yet they will repeatedly go after the yella terras. I have used them on 4 builds not including a procharged 427 lsx that made over 1k hp. They were the new LS3 versions.
I have actually not installed any yella terras to date.
Old Jun 11, 2014 | 09:03 PM
  #37
JakeFusion's Avatar
Super Hulk Smash
Ron, the stockers with either the Comp trunion upgrade or the high dollar CHE bronze bushing upgrade might be worth a look. I think it's like $420 if you supply the stock rockers to CHE/WCCH.
Old Jun 12, 2014 | 05:45 AM
  #38
vettenuts's Avatar
Ron,
Do you know when you bought this set? As I recall, it was a fairly recent purchase/installation. I bought mine from BTR and they told me on the phone they had just got the sets in from Yella Terra.
Old Jun 12, 2014 | 07:39 AM
  #39
00SlvrSS's Avatar
Well that's just what I needed to see. I just upgraded my roller rockers. They are slightly noisey, but that's kind of what I expected out of them. They were soaked for 2 days and also had assembly lube on them. That's all bad news.
Old Jun 12, 2014 | 08:40 AM
  #40
truckdoug's Avatar
is there any reason I don't see many harland sharps in LS motors? could be im not paying attention I suppose.
Had nothing but good experiences with them in my solid lifter SBC/BBC days
