New YT rocker failure
Old Jun 24, 2014 | 06:24 AM
  #61
vettenuts's Avatar
Originally Posted by racer8088
A lot of problems come from out of control valvetrain systems where crazy lobes and heavy parts are thrown together with wrong springs or incorrect spring setup etc. even coil bind. I've seen it all.
What are your thoughts on the role that pushrods play in this? I did notice a big difference in the upper RPM when I went from 5/16" pushrods to 3/8" double taper. The upper curve smoothed out and raised a bit as well.
Old Jun 24, 2014 | 08:44 AM
  #62
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
The scorpions are on their third revision as well, and to date, I haven't heard of a single failure (new design)
Old Jun 24, 2014 | 10:12 AM
  #63
RonSSNova's Avatar
I prob should check spring pressure. They are the AFR PAC upgrade.
Do you guys know if the on the car spring testers work with the LS engines?
It would be a bitch to pull them all off w/o removing the heads.
8k miles on them, with a lot of dragstrip passes. 6600-6700 shift points.
Old Jun 24, 2014 | 04:37 PM
  #64
vettenuts's Avatar
Are these the AFR 8019's? Give Tony a shout but I don't think they would need replacing. You could pull one set and check. I would check one of the pair that had the bad rocker in case there was any shock inputs that might have hurt the springs from the slop in the roller. Everything I have seen on these springs they take a lickin and keep on tickin.
Old Jun 24, 2014 | 08:20 PM
  #65
RonSSNova's Avatar
Yes, 8019's. I put them in when I did all the mods.
My heads were used, and had the 8017's installed.
Old Jun 25, 2014 | 06:46 AM
  #66
vettenuts's Avatar
Have you thought about stiffer pushrods (3/8 double taper) especially since you race the car?
Old Jun 25, 2014 | 03:47 PM
  #67
RonSSNova's Avatar
Nope. The vettes racing days are all but over.
Compared to my Nova, it's a stone now. Just want it running nice and reliable.
Old Jun 25, 2014 | 08:19 PM
  #68
JakeFusion's Avatar
Super Hulk Smash
I'd still run a stiffer pushrod...
Old Jun 25, 2014 | 08:54 PM
  #69
miami993c297's Avatar
I am using the Manton Series V in my engine...I like the power curve of this engine being flat from 6000rpm to 7400rpm.
Christian
Old Jun 25, 2014 | 09:00 PM
  #70
RonSSNova's Avatar
Christian
What lifters?
Old Jun 25, 2014 | 09:03 PM
  #71
What lifters?
Morel 5206...preload between 0.020 and 0.030...pushrods are to sizes.
Christian
Old Jun 25, 2014 | 09:27 PM
  #72
RonSSNova's Avatar
Christian
I'll have to race you with my Nova then.
Old Jun 25, 2014 | 09:54 PM
  #73
I hope you Nova is as drive-able in heavy traffic and can go and get the groceries as well as my monster can...on the side of toping 7400 rpm fifth gear @ 192mph...
Christian
Old Jun 25, 2014 | 10:18 PM
  #74
RonSSNova's Avatar
Got me, it won't go 192.
Old Jun 26, 2014 | 07:10 AM
  #75
vettenuts's Avatar
Christian
Yikes!!! We have so many LEO's around that I have trouble banging the first two gears. Tourist area
Old Jul 6, 2014 | 09:10 PM
  #76
BADD SS's Avatar
IF you have a stock type head, you cant beat a stock rocker w/trunnions...period.
Seem to be working on my junk @ 8,000 rpm, for 4 years with a bigger cam than 99.8% of the ones here..... Just saying, aluminum rockers suck, plus more weight over the valve.
