Holley valve covers using LS1 coils
Old Jun 13, 2014 | 11:12 AM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
Default Holley valve covers using LS1 coils
I've seen a few threads about this and recently I had a customer with the same problem. The Holley Valve Covers were not made for LS1 coils. Most people go to the LS3/LS7 coils and use them. But you can use LS1 coils with a little work. I've seen one other guy make a nice offset bracket but since those aren't available to the public here is what I did: You will need a dremel cut off wheel and you will have to cut the ends of the coils. Instead of it having two holes you will have two slots. Here is a picture of a coil that I did to show a customer. Don't mind the paint on the coil. It was just a first coat anyways. I will be repainting them after it has been slotted.
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old Jun 15, 2014 | 11:52 AM
Pharcyde50's Avatar
Which plug wires can you run with that setup?? Will a stock ls1 length work or do you need a longer truck wire?
