HUGE cam that i just bought.......
thanx again fellas
mike
thanx again fellas
mike
then that way yall can see if ya think it will fit or not (this would be GREATLY appreciated by me!!!) if nothing else, ill just buy another cam and keep this one till its time to go even bigger in my set up... i really dont care, i mean i dont HAVE to run this cam. its not like im ready to do it tommarow.
now in theory, if i cut the pistons, THEN it would fit??
thanx everyone!!!
mike
Edit: I just went to comp cams website and the largest cam they have for an LS1/LS6 motor is the 238/240 .605/.609 112 are you sure the 238/242 cam is the one you got?
i just dont know what i should do as in if i DO put this cam in and i spin the motor over a bunch and it dont hit. ill try to get all the other numbers for the cam and post em...
thanx guys, yall been a big help!!
mike
With 4* advance built into the cam, it definitely will NOT fit with stock pistons...no if's, and's, or but's. So you have two choices, notch the pistons or pick a different cam. Good luck. mike
crap... my bad... dang typo. its a 236/242.
and i know that this cam is big for a street application, but i have had four different cams in my car now and i know what its like to have a big cam in a car. the reason i picked one so big is because for the future build that i plan on doing
when i stroke the motor and get some hellacious heads! but i have been running some numbers and it will be cheaper for me to just buy another cam then to spend the money on damn bolts and gaskets and isky tools to flycut that biatch. so if i do decide that the cam dont fit, then ill just get another cam for CHEAP this time and just run it for 6 months.i know that will 4* built in that the cam prolly wont fit, but what if i was to get an adjustable timing set and retard that bitch 4 degrees back?? would that help it? and can i do this with no ill effects? what do yall think???
thanx!
mike
i swear, this is about to get a little bit more involved then i would like for it to be... lol... the isky tool will cost me about 150$ to rent, along with the 240$ head gasket kit from thunder so that is 390$..... i think ill eat my losses and get a new cam if i do determine that the cam will not fit. its time to get this beast rollin!!!!thanx for the help!.... any more input would be appreciated!
mike
well... that DOES make me feel better ... LOL... i think i have figured out what im going to do... if it IS determined that the cam will not fit, then i will get the damn hotcam kit for now (425$) and just run through the summer with that, until dec. when i can afford the heads and isky tool to cut this ****, and i will have my BIG cam sitting by, waiting for me > : ) Sell the hotcam for 150$ and put it down on the head gasket/bolts swap. THEN cut the pistons, get the heads, put in the big cam... and life will be good
any more opinions?????
mike
236/242 .601/.610 112 +4, IVO = 10, IVC = 46, EVO = 57, EVC = 5, (@.50)
what do ya'll decifer from all that???
thanx!!
mike
thanx!!
mike
if i were to cut the pistons would it fit then??
thanx!
mike
