Does anyone know a way...
Old Jun 16, 2014 | 07:41 PM
badformulaLS1's Avatar
Default Does anyone know a way...
to rethread the furthest back rocker bolt hole on cylinder 8 with it in the car without removing the head? It somehow got cross threaded to hell by a lightly screwed in bolt on the valve spring tool... Had it towed to the shop and he says he doesn't think he can do it without removing the head which I don't have the funds to pay for. Just wondering if anyone has had this happen to them and if there is a way to repair the thread without removing the head.
Old Jun 16, 2014 | 08:27 PM
JakeFusion's Avatar
Super Hulk Smash
I'd remove it. Even if you're careful, I'd be afraid of getting metal shavings into the engine. Plus there is almost no room to work back there.
Old Jun 16, 2014 | 08:32 PM
Alright, I guess it's gona have to sit for a while then unfortunately... Was just curious if anyone had a method that would work with the head on.
Paul Bell's Avatar
That's MISTER MODERATOR
You can't really re-thread or fix threads once they're sheared off or crushed. You'll need to HeliCoil it so the head's gotta come off to get it drilled & tapped straight.
Old Jun 16, 2014 | 09:32 PM
Im aware of what needs to be done to repair it, I was just wondering if it was at all possible to do it with the head still in the car.
Old Jun 17, 2014 | 06:11 AM
vettenuts's Avatar
Sometimes the best way is to do the most work, i.e., remove the head. If it gets buggered more trying to fix it in the car then you will be buying a new head too. That's one advantage the Vette has over the f-body, the rear of the engine is very accessible.
Old Jun 17, 2014 | 08:33 AM
Paul Bell's Avatar
Originally Posted by badformulaLS1
to rethread the furthest back rocker bolt hole on cylinder 8...
You can't really re-thread or fix threads once they're sheared off or crushed...
Im aware of what needs to be done to repair it...
My advice was based on your first statement that you wanted to re-thread damaged threads. I wanted to make sure you were aware that broken threads can't be brought back to a useable level.
Good luck with the repair, let us know how it goes.
Old Jun 17, 2014 | 11:51 AM
Yeah I worded it poorly my mistake. Head will be coming off today.
