stupid 98 starter bolts!!!!
Old Jun 19, 2014 | 04:34 PM
hotrodT/A's Avatar
Default stupid 98 starter bolts!!!!
I have a 98 z28 I'm doing h/c/I swap and I'm at the part where I need to lock the flywheel to remove the crank pulley. On the 98 the bolts are 15mm instead of 13 mm and I see why. You can't get a socket around the bottom one because the plastic cover is in the way and you can't remove it because the starter is in the way. Yes I can fit a wrench on it but it won't move enough to break it free. Any suggestions? Maybe another way to remove the crank bolt/pulley? Any help is appreciated!
Old Jun 19, 2014 | 04:42 PM
98CayenneT/A's Avatar
Try a thinner socket or file the plastic down a bit, I was able to get a socket in there, I had a 15 socket that would fit and one that would not
Old Jun 19, 2014 | 04:46 PM
hotrodT/A's Avatar
What a PITA I'm gonna look for a thinner socket later then
Old Jun 19, 2014 | 04:49 PM
thunderstruck507's Avatar
Yeah, same here I had a thinner one that would work (craftsman I think) but the Channel Lock one from my kit didn't fit.
Old Jun 19, 2014 | 04:53 PM
Ya, I got pissed off, could not get a socket on there, could not get the plastic piece off then I just reached for a different 15mm socket which was a hex/6 pt craftsman slipped right on
Old Jun 19, 2014 | 05:09 PM
hotrodT/A's Avatar
Thanks really helpful guys! Craftsman 15mm here I come
Old Jun 20, 2014 | 08:57 AM
You just reminded me next time I have that off me and my grinder are going to have a field day.
