Swapping Ls1 to Ls6 intake what to exspect
Old Jun 25, 2014 | 03:52 AM
Goodkat's Avatar
Default Swapping Ls1 to Ls6 intake what to exspect
In a couple days I'm gonna be doing the swap to an Ls6 intake on a 98 z28 now my concerns are are there any issues I'm going to run into I'v heard its a pretty basic swap but will there be any parts I will to remove/purchase for swap? I'm basically looking for a break down of what I need or don't need for the swap.
Old Jun 25, 2014 | 06:54 AM
1 Slow WS6's Avatar
Here ya go. http://www.ls1howto.com/index.php?article=5
Old Jun 26, 2014 | 04:17 AM
Goodkat's Avatar
Thanks slow that will work perfectly
Old Jun 26, 2014 | 09:44 AM
1 Slow WS6's Avatar
No problemo
Old Jun 26, 2014 | 10:02 AM
Transambrandon's Avatar
Don't break the oil pressure sending unit, behind the intake! Just did the swap and I broke it wen swapping. Extra $50 I didn't need to spend lol
Old Jun 27, 2014 | 12:25 PM
bsf's Avatar
bsf
It has been quite some time since I did mine, but I believe I did not change the coolant, crossover lines. I did carefully grind the ribs out of the bottom of the intake where necessary to provide clearance, IIRC. I may have tweaked the lines a bit also. I have not noticed any coolant leaks. In fact, I just did a coolant system pressure test and ran the engine for a while with transmission and clutch out.
I think my intake manifold is seated fine. If you go this route, make certain everything seats and seals properly.
Old Jun 27, 2014 | 05:20 PM
1 Slow WS6's Avatar
How did you do that? I've taken mine off and put back on a lot.
Old Jun 27, 2014 | 05:28 PM
Majestic9C1's Avatar
yeah I dont know how you do it either.. just gotta be careful with the vacuum and electrical connections
