Need help LQ4
The problem with an LQ4 in a performance application is the dished pistons. The volume of the dish reduces compression ratio, which will hinder power. You can find brand new Speed Pro flat top pistons for roughly $250 and bump up compression almost a full point.
The stock 317 castings also have a large chamber, which again, reduces the compression ratio. Since the engine will be disassembled and the heads will be off, I would sell the 317's and purchase a set of 799 or 243 castings. After selling the 317 heads, you may only be out $150-200 for the 799/243 heads.
Those two changes would bring your compression ratio up from about 9.4:1 to roughly 11.2:1 for less than $500 on top of a normal rebuild cost. The increase in compression will bump horsepower and more importantly torque, all across the RPM range to get a big heavy truck moving. With a decent set of 1-3/4" long tube headers and an appropriately spec'd cam, 430whp should be cake, even through a heavy truck trans and drivetrain, and still provide a good broad powerband.
