01 Camaro SS No Start HELP!!!!! :(
Old Jun 30, 2014 | 07:51 AM
stangstomper68's Avatar
Default 01 Camaro SS No Start HELP!!!!! :(
ok here is the low down. Had to do an engine rebuild on my ls1. Had another crank turned .010/.010, new rings, and bearings. Re-installed engine and now it wont start. Turns over fires for maybe 2 seconds and turns off. Checked with a pocket scanner and it intially showed a p0356. Checked for 12 volts and a ground and both were present. Changed the crank sensor with no change. Also doesn't seem the tach works, but honestly it doesnt run long enough to register. If you spray starting fluid it will crank and run as long as you want it to. Soooo does this mean I have a reluctor ring issue, Wiring still yet, or maybe something to do with the wiring on the back of the engine because I was under the impression that the cam sensor fires the injectors. Any help would be great because I am at a loss here.
Old Jun 30, 2014 | 08:26 AM
Exeodus's Avatar
Have you check your feul pressure?
Old Jun 30, 2014 | 08:28 AM
yes Exeodus it has fuel pressure and the pump comes on with the switch.
Old Jun 30, 2014 | 09:21 AM
Paul Bell's Avatar
That's MISTER MODERATOR
This indicates you have ignition but no fuel.
You'd probably get better answers in the PCM diagnostics section, not the crank, rod & piston section.
Old Jun 30, 2014 | 10:09 AM
Cool thanks Ill post it over there.
Old Jul 2, 2014 | 04:53 PM
Bama99z's Avatar
Heck it must just be a 01 SS issue. I went through the lamost exact thing ( Reluctor Wheel ). Well that was my probles at least.
https://ls1tech.com/forums/generatio...correctly.html
