Oil pressure
Old May 19, 2004 | 10:16 PM
LS1 Brent's Avatar
Default Oil pressure
My oil pressure seems to be kind of low. When it's at idle (700 rpms) it is a little bit above the first while line. 20 maybe? Then it stays right at 40 when I'm driving it normal. Is this a sign of a bad oil pump???
Old May 19, 2004 | 10:19 PM
99WS6LS1T/A's Avatar
Mine runs the same pressure and has for a while a compression check was done on my car yesterday 7 cylinders had 180 lbs. and #8 had 170 lbs. I'd say you're fine. What is it @ WOT?? Mine shoots to 65-70.
Old May 19, 2004 | 10:21 PM
sawedoff's Avatar
No, it's very typical. The OEM guages are really nothing more than idiot guages. There's nothing wrong with your pump either. You can go to an aftermarket guage for accuracy, if you'd prefer to.
Old May 19, 2004 | 10:39 PM
P Mack's Avatar
Mine stays at 40 warm idle, and 50 or 60 at cruise and cold idle. Of course that's with the stock idiot guage, so those numbers could be wrong.
Old May 20, 2004 | 12:59 AM
lsx24's Avatar
98's are known to have more accurate guages. Mine does that too.
Old May 20, 2004 | 09:38 AM
SSCamaro99_3's Avatar
I get 42-44 atwarm idle, 60 at cold idle, 60 at cruise, and a bunch more at WOT. Stock guage.
Old May 20, 2004 | 02:17 PM
Bhogan909's Avatar
Could be a bad o-ring
Old May 20, 2004 | 11:04 PM
00blackbird's Avatar
I would try changin your oil filter. Mines gone that low before to, and the inside of the filter was damaged.
Old May 21, 2004 | 07:13 AM
cablebandit's Avatar
it's normal. Don't worry about it. Your oil pump is bad when you have ZERO oil pressure
Old May 21, 2004 | 07:44 AM
Viper's Avatar
FWIW, I thought I'd throw this out.
I had 30-40psi at idle, 60-70 WOT for a long time.
Got a new PCM yesterday, installed it, drove around.
Idle is now at 20, wot is 40-60.
Is it possible a tune can change the pressure, or mess with the gauge?
I lost an engine due to 0 oil pressure, so I obviously keep me eye on this quite regularly.
Thoughts?
Old May 21, 2004 | 09:02 AM
I would consider this as well. We had some pressure issues caused by the O-ring.
