436 stroker with STAGE II heads............
242/242 .610/.610 114 lsa
11:1 compression
Curious.
480 rwhp with no dyno tricks in an a4 (with big convertor) is tough.
I was just concerned whether or not it should get ported more before its assembled.
But it did do 480 RWHP through my A4 and with a cam that is supposedly tame 1 1/2 years ago, and thats without a full pull. It only went to 5,000 rpm on the dyno.
So should I just not worry about it?
Thanks.
AND HOLY HELL...Thanks to ARE for what they've done so far
Pump gas?
RWTQ?
Pump gas?
RWTQ?
CR is 11.5-1
93 Octane.
I CANT verify any of the dyno info. I was not there when it was done. I belive that JD, JPR and Brian from PCM can not lie all at the same time. I have no reason to believe that BRIAN is lying, but JPR and JD, well thats another story.
CR is 11.5-1
93 Octane.
But also remember, mine pulled 480 at 5,000 rpm, so really, I never had a full pull.
So maybe you got yourself a badass engine.
Have you ever been to the track?
This time around it should be better than before.
We'll see soon enough
CR is 11.5-1
93 Octane.
I lost 30 RWHP on my JPR S2 heads and cam package as soon as I drove it away from JD's dyno
Dyno numbers went from 422 at JD's to 392 and 390 at two different dynos.
Dyno numbers went from 422 at JD's to 392 and 390 at two different dynos.Curb Weight= 3600
Motor= 427
Tranny= 400 + brake 3600 stall
Rear= 12 Bolt 4:10
Tire= 28x10.5x15 Hoosier Drag
ET=Priceless
***** all the shitty sponsors.
Soon, Soon ....
Either that, or there is some funny business going on with the weather station. I know JPR pumped my tires way up (40-50 PSI), not sure how much effect that has, but I have heard of it as a dyno trick. We also dropped the y-pipe, removed the air filter...tried every trick in the book short of removing the belts.
. with that 436 i'd look at nothing less then some STG 3 heads.
