Rear main seal
Old Jul 9, 2014 | 08:30 PM
BEAST_WS6M6's Avatar
Default Rear main seal
Sup tech, i narrowed down a leak and im debating on buying from http://www.gmpartsdirect.com/results.cfm,part number 12639250 before i buy i have a question. Do you guys know if this seal is made of teflon?, cause if it is then im assuming its recommended to be installed bone dry. As for the complete housing, would i just install it as it comes, meaning when i remove my (old) cover, gasket, seal etc. do i just do a straightforward install with this new one?
Feedback would we appreciated
Old Jul 10, 2014 | 12:06 PM
Bump with link to the listing..
http://www.gmpartsdirect.com/results.cfm?singlepart=1&partnumber=12639250&tid=1 295
Anyone?
Old Jul 10, 2014 | 12:10 PM
gMAG's Avatar
Yes, install the whole setup, minus the white support.
It comes with light grease applied to the inner edge of the seal.
I don't know if the seal is made of Teflon.
If you haven't done a rear seal before, it is important to exactly center the seal to the crank hub.
saccitycorvette (a sponsor) sells a rear main seal centering tool.
https://ls1tech.com/forums/generatio...one-these.html
