Stock Rods
Old Jul 11, 2014 | 06:06 PM
RezinTexas's Avatar
Originally Posted by Paul Bell
If the original rods have a press-fit piston pin, you'll destroy the pistons trying to get them out.
I agree that aftermarket rods are an overall better option, however this is how you can remove the OEM press-fit rods without breaking the pistons.
Old Jul 11, 2014 | 06:49 PM
BlackedOut LS1's Avatar
Futral motorsports in Walker LA.
Old Jul 11, 2014 | 08:03 PM
Paul Bell's Avatar
That's MISTER MODERATOR
I tried something similar to that and they shattered.
Old Jul 11, 2014 | 08:25 PM
Mercier's Avatar
Allan Futral has a solid reputation around here. Several close acquaintances that are happy customers.
Old Jul 11, 2014 | 10:28 PM
RockinWs6's Avatar
GM has a dealer tool made just for changing pressed in rods. I used it alot .
Old Jul 12, 2014 | 12:04 AM
truckdoug's Avatar
on sbc's i used a propane torch. dunno I'd mess with one on an ls though. so much less meat in the pin boss it'd be easy to hot spot it.
yup GM has a special tool, or a reasonable machine shop has a rod oven.
I got quoted $60 for a piston swap, but I ended up with floaters in the end.
