408 push rod length (pic inside)
B) Pushrod length will not fix the wipe pattern. This isn't a SBC. The LS rockers are pedestal mount, so changing the wipe pattern involves raising or lowering the rockers is relation to the valve.
C) I've seen similar symptoms on two different cars. The first had an issue with the 24x reluctor separating (it's a two piece reluctor) and was fixed by replacing it. The last one was fixed by replacing the reluctor and clearancing the oil pump from the timing chain. Someone forgot the oil pump spacers with a double roller chain, so the chain was digging into the pump housing HARD. Not sure if that fixed it or it was replacing the reluctor, but the car ran flawlessly after that.
