Ls1
Old Jul 13, 2014 | 07:53 AM
cutlassmann's Avatar
Default Ls1
hello what do it means when your riding and punch it it's back fire through the exhaust and it hesitate to pull I'm running a LS1 out of a 2000 ss camaro in my 1972 cutlass with 4L60E do you think it needs to be retune.
Old Jul 13, 2014 | 09:40 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Assuming you're using a GM LS1 PCM & wiring harness, is there a SES light? Any codes?
Old Jul 13, 2014 | 09:48 AM
Yes I'm using PCM and bought a after market wiring harness haven't had it hook up to see what codes it gives have you ever had this issue and do you think it's ok to drive.
Old Jul 13, 2014 | 09:50 AM
Paul Bell's Avatar
I'm thinking you have a fuel pressure problem. What kind of fuel pump and pickup system did you use?
Old Jul 13, 2014 | 11:25 AM
I'm running a areomotive stealth system tank and fuel pump.
Old Jul 13, 2014 | 11:29 AM
Default ls1 engine
could a burnt wire make it run like that?
Old Jul 13, 2014 | 11:30 AM
Default LS1 Engine
my car and motor
Old Jul 13, 2014 | 11:32 AM
Default wire
heres the wire its not burnt all the way through but could that make it run that way.
Old Jul 13, 2014 | 05:22 PM
That was the issue the spark plug wire wow thank god it runs great! Thanks for y'all help...
Old Jul 13, 2014 | 08:18 PM
Paul Bell's Avatar
Yessir.
my car and motor
Looks nice!
Yessir.
Great!
Old Jul 14, 2014 | 04:19 AM
Default Vhx gauges
Currently need to get my electric-life power windows working properly and have my Dakota Digital VHX gauges looked at(not showing gear changes always in first gear) any help would be greatly appreciated
Old Jul 14, 2014 | 08:34 AM
Paul Bell's Avatar
None of that is internal engine related.
I suggest you head over to out conversions section, they'll help you out.
https://ls1tech.com/forums/conversions-hybrids-28/
