LS1 rebuild needed - sleeper build? (not too choppy)
i really like my TSP 228R cam and stage 2.5 5.3 heads setup, but i think the years of spinning the stock bottom end to 7k finally caught up with me. not 100% sure, but the sound its making is probably pointing to spun rod bearing. i'm planning to take it to a shop to get work done on it and they'll send the engine out to a reputable shop that builds a lot of race motors.
i'm mostly looking for opinions and ideas from people who have done rebuilds. all options seem pretty expensive, so i want to make sure i do it right the first time around.
i can't go too nuts because i live in CA where everything is illegal. i got a smog hookup, but mods can't be so obvious that a cop feels he needs to pull me over. so far, the 228R 114LSA (with cats and mufflers) seems OK as i've idled next to cops at stop lights without getting a second glance.
i contacted TSP and they suggested 383 stroker with their torquer v2 (232/234 .595"/.598") should be relatively mild and give more power/torque. i'm considering this, but am open to other ideas due to cost.
so what do you guys recommend?
would buying a preassembled shortblock from somewhere be cheaper? (assuming i reuse the prc stage 2.5 5.3 heads heads)
I DD a MS3 cam and never had issues with cops in Ca. I had a cutout too. 383 is your option with a 346 LS1 block. I'd give Ed Curtis, Geoff @ EPS, Martin @ Tick or Brian Tooley of BTR a call and see what they'd recommend.
If you have a smog hookup it shouldn't matter and I'd do the most I could afford. Running a good CB that is tame helps a lot. My Hooker Aerochamber tamed the MS3 quite a bit but still sounded good.
I run those heads with a cam similar to the MS3 on a 370 ci 6.0 and it runs hard for what it is. Op have you checked out Thompson Motorsports? If not I highly recommend that you do. After tons of shopping around I found them to be the best overall deal
Do you mind pm'n me what you paid for the 370.
We have some excellent options in all variations for the LS platform, give us a call if we can help in any way.
Thank you for the plug HCI2000SS, We appreciate our customers sending people our way.
