new to this Ls world
Old Jul 13, 2014 | 06:27 PM
jking78's Avatar
Default new to this Ls world
I have a stock 6.0
I the opportunity to buy this cam
Comp cam part# 54-416-11
Is anyone else using this cam & what is your opinion
Old Jul 13, 2014 | 06:58 PM
HCI2000SS's Avatar
Specs?
Old Jul 13, 2014 | 07:11 PM
Always2Slow's Avatar
Originally Posted by jking78
I have a stock 6.0
The cam is fine if you wish to stay on stock yellow springs or move to an entry level beehive spring. If the goal is to have an extremely long spring life and really easy on parts this cam can work. If you would like a balance between power and longevity there are better options out there.
Old Jul 14, 2014 | 11:15 AM
jking78's Avatar
[QUOTE=HCI2000SS;18319285]Specs?[/QUOTE
It will be a dd but looking to get a streetable 450+rwhp
Old Jul 14, 2014 | 11:18 AM
jking78's Avatar
That exactly what I'm looking for. I will adding ls6 intake
Old Jul 14, 2014 | 12:30 PM
Rise of the Phoenix's Avatar
Can't read the specs, but you're going to need a pretty aggressive cam to get to 450 rwhp with a LS6 intake. Something in the mid to high 230's on intake and very high to low 240's exhaust.
Old Jul 14, 2014 | 02:18 PM
jking78's Avatar
Here are the can specs and I'm assuming this wouldn't work
Rpm 1600-6600
Valve timing 0.006
Lobe separation 112°
Intake centerline 110°
Duration intake. Exhaust
273. 277
220. 224
0.53. 0.534
0.313. 0.315
Exhaust closes 25 atdc
Opens 73 bbdc
Intake opens 27 btdc
Closes 67 abdc
Old Jul 14, 2014 | 02:25 PM
You're going to need a lot more cam than that to reach your goals. Your best bet would be to get with one of the vendors on here and have them help you out. Martin at Tick Performance is a great guy who can help you out.
Old Jul 14, 2014 | 02:55 PM
jking78's Avatar
OK thx
Old Jul 15, 2014 | 12:17 AM
The cam that you want would be 1 of two options 225 lsl lobe 232 XE lobe on a 111LSA installed at a 110 intake center line or for a longer spring life go with a 226 intake LXL lobe 232 exhaust XE lobe on a 111 LSA installed on a 109 intake center line.
Both of these cams will give you a great responsive motor for the street and get you to within reason of your 450 to the tire goal.
Old Sep 1, 2014 | 09:42 PM
jking78's Avatar
Finally had a chance to Crack open my lq4 to find out that it's missing push rods and head bolts ����. So now that it's open
What are the advantages of swapping pistons and rods from a
LQ9
Old Sep 1, 2014 | 10:17 PM
JoeNova's Avatar
Restricted User
Higher compression and less weight. You'll never get close to their potential on an N/A motor so unless you're dying to lose a few grams off of your pistons/rods its not really worth it.
You can mill the heads or swap to 799/243 heads for more compression and better flow.
Old Sep 2, 2014 | 01:30 PM
jking78's Avatar
The motor came with a set of 317 heads with yellow springs I was told those where the best ones to have because they are ls6 springs and heads
Old Sep 2, 2014 | 01:36 PM
jking78's Avatar
I guess what I'm looking for is a great combo that's gonna last for a while but also put me in the power range of 450- 50th on a dollar budget if possible
jking78's Avatar
Old Sep 2, 2014 | 04:40 PM
JoeNova's Avatar
Restricted User
317 heads are not LS6 heads. LS6 heads are 243 heads, and eventually 799 heads when they outsourced a second supplier to cast them.
317 heads are not bad heads, but probably not best for what you're doing.
Old Sep 2, 2014 | 06:17 PM
jking78's Avatar
So my best bet is to find a set of 243 or 799 heads. Would I be able to use the yellow springs or try and get a better set of springs?
Thx JoeNova for your help
Old Oct 16, 2014 | 09:27 PM
jking78's Avatar
Ok guys I'm looking for a good set of push rods and I've read that lq4 push rod length is 7.3 or 7.4 any info to help me select the right push rods
Old Oct 17, 2014 | 07:24 PM
DREAMZ28's Avatar
Buy yourself a pushrod checker and check yourself if you want it to be correct without any guess work.
Old Oct 18, 2014 | 01:05 AM
jking78's Avatar
When I bought the motor I figured it would have the pushrods but it don't so now I have to replace the pushrods so I might as well buy better pushrods then stock
