pcv ?'s
Old Mar 12, 2003 | 11:43 AM
last of the Z28's's Avatar
Default pcv ?'s
if you have a 2001-2002 ls1 engine do you have the ls6 pcv setup from the factory? just curious. thanks!
<small>[ March 12, 2003, 11:45 AM: Message edited by: last of the Z28's ]</small>
Old Mar 12, 2003 | 11:54 AM
MikeMs01TA's Avatar
Default Re: pcv ?'s
Nope, 01 LS1 here.
Old Mar 12, 2003 | 01:46 PM
NX†C's Avatar
Default Re: pcv ?'s
on the 2001-2002 cars they come
with the LS6 pcv system.
If you were to take off your
LS1 intake and look on the
underside, you would see something
likes this:
<img src="http://c5.kicks-***.net/~eclark/images/2003Mar10/l/ls1intake%20001.jpg" alt=" - " />
On the underside of the LS6 intake
on 2001-2002 cars the coolant lines
are only a crossover piece b/n the
heads and dont run the length of
the valley cover. Reason was that
there was an improper seal between
the intake runners on the heads
and the ports on the intake. So
all that is contained under the
LS6 intake is the 2 knock sensors
and their necessary wiring. A
good fix though for any oil
consuption issues is to swap to
the LS6 valley cover which plugs
into the intake to siphon out
pooling oil and put it back into
the block. A more efficient and
cheap modification (less than $100
for it). The only catch is you must
shave off a small portion of
the block in order to have it seal.
But you also can clear out a lot
of the pcv tubing to clean up the bay
with this valley cover installed. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
<small>[ March 12, 2003, 01:51 PM: Message edited by: X']['C WS6 ]</small>
Old Mar 13, 2003 | 12:11 AM
Damndobbs's Avatar
Default Re: pcv ?'s
is the difference the location of the valve? i.e. valley cover
Clint
Old Mar 13, 2003 | 12:18 AM
Default Re: pcv ?'s
i was wondering because we have the ls6 intake and i here that it interferes with the ls1 valley cover. so gm just modified the ls1 valley cover? or am i wrong all together?
Old Mar 13, 2003 | 12:26 AM
Damndobbs's Avatar
Default Re: pcv ?'s
i read a post saying something about the pcv on the ls6 being relocated to aid in that problem...there were some vacuum leaks for the intake and people were burning some oil...
https://ls1tech.com/ubb/ultimatebb.p...c;f=1;t=011664
Clint
<small>[ March 12, 2003, 12:28 PM: Message edited by: Damndobbs ]</small>
