ls1/lq4 swap/build issues
Old Jul 24, 2014 | 10:46 PM
Austin1249's Avatar
Default ls1/lq4 swap/build issues
Alright guys I have ls6 patriot heads that I'm putting on my lq4. I'm putting brian tooley dual valve springs. The valve seats wouldnt fit on my valve guides. I throw the stock ones on then I went to put the valve seals on and they seem extremely to tight. So I assume my valve guides are larger. So I can I get seats and seals for my guilds if that's my issue.
Second I want to be sure I'm checking pushrod length correctly I've put a cylinder at tdc and checked the length then added preload. But what's puzzling my mind is I came up with 7.450. Which I have the patriot heads, a tickperformace sns.stage 2 cam, and morrel lifters.
Old Jul 25, 2014 | 08:36 AM
Brian Tooley Racing's Avatar
Did you lube the ID of the seals? That can help with installation.
Which Morel lifters do you have? The 5290,5206 have a taller pushrod cup and require shorter pushrods, the 5315 have a shorter pushrod cup and require longer pushrods.
