Help with pistons plz!
Old Jul 27, 2014 | 06:14 PM
99Z28camaro's Avatar
Default Help with pistons plz!
I am rebuilding my 408 and was wanting to up the compression this time. I picked up a new set of diamond nitrous dome pistons part #11562 at a swap meet and was wanting to know if they will work with my 243 heads? Did some searches and couldn't find much. Thanks for any help
Old Jul 27, 2014 | 07:23 PM
svede1212's Avatar
10cc is a lot. That's going to put your CR over 13.5:1
Old Jul 27, 2014 | 07:32 PM
Yea should be right at 14:1
Old Jul 27, 2014 | 07:38 PM
svede1212's Avatar
Could always get L92 heads or are you burning something besides 93 octane
Old Jul 27, 2014 | 07:53 PM
Yea I will run race gas.. I can get 100 at the pump here where I live or 110 at the track... Keeping my 243 heads they are highly ported and flow extremely good
Old Jul 27, 2014 | 07:58 PM
Don't want to change heads to lower the compression.. Already sits at 12.5:1 now with the flat tops that's in it.. Just picked these up cheap and want to raise the compression some.. Guess I will just have to put one on a rod and install it to check ptv clearance and make sure everything clears
