Ring job on 6.0 ls2
Old Jul 28, 2014 | 09:03 PM
JChastain's Avatar
Default Ring job on 6.0 ls2
I picked up an ls2 out of a trailblazer ss. I'm wanting to put pmd rings from an ls2 vette. Are the pistons the same between these 2 6.0's? Also any help with direction on where to get the right rings is appreciated. Thanks
Old Jul 28, 2014 | 10:14 PM
KCS's Avatar
KCS
Moderator
They may not be. I think there were different rings sets for different years/models. Some had a 1.5/1.5/3.0mm package, some had thinner. I think Hastings has a catalog that could help you out, or you could use a dial caliper and measure the ring thickness to verify.
Old Jul 29, 2014 | 12:32 PM
JChastain's Avatar
Thanks for the reply
Old Jul 29, 2014 | 12:53 PM
Fry_'s Avatar
Have you done a cranking compression test or leak down test. Unless the motor has poor ring seal then you might do more harm than good tearing the motor down and doing a at home rebuild. Also it's not exactly cheap to rebuild a LS motor, gaskets, seals, and replacing all of the TTY bolts, even a "cheap" rebuild starts to get expensive.
Old Jul 29, 2014 | 02:13 PM
JChastain's Avatar
It spun a bearing so that's the reason. While it's apart I want it done
Old Jul 29, 2014 | 03:48 PM
Fry_'s Avatar
I'd say that's a pretty good reason. It seems like from time to time someone joins and wants to rebuild their motor just because it seems like a good idea. Good luck with your rebuild.
Old Jul 29, 2014 | 04:03 PM
v8pwr's Avatar
The Trailblazer SS is an LS2 and uses the thinner ring package.
Old Jul 29, 2014 | 09:17 PM
JChastain's Avatar
Will the thinner rings still seal ok if I'm going for a 500rw NA build? I might spray a little nos in the future. Thoughts?
Old Jul 30, 2014 | 06:03 AM
v8pwr's Avatar
The stock LS2 rings are actually a very good ring for a factory application. For most people I recommend Mahle's Original replacement series which usually have a moly coated steel top ring instead on an iron ring, napier second, and they're pretty affordable. If you make more than 600 then step up to Total Seal AP with a nitrided steel top.
Old Jul 30, 2014 | 08:22 AM
KCS's Avatar
KCS
Moderator
Thinner rings are good for sealing the combustion chamber. They conform to the bore better and reduce friction at the same time.
Old Jul 30, 2014 | 06:10 PM
JChastain's Avatar
Thanks for the replys. I think I'm going to just go with some gm replacements
Old Jul 30, 2014 | 06:57 PM
v8pwr's Avatar
The GM replacements are good rings but expensive. I think that Mahle makes them for GM. The GM rings are a steel top ring with a napier second but I think they're around $250 for the set.
Old Jul 31, 2014 | 04:30 PM
JChastain's Avatar
Just got some gm's for $200. Thanks guys
