Notching Oil Pan for Stroker
Does anyone have any pics of there notched pans? Also how much clearance is recommended
Has to be the windage tray. Did the same thing, spaced it off the main studs with 1 flat washer per stud. There are places to buy windage trays for bigger stroke cranks if you don't want to use washers.
It must depend on the rods or bolts that are used... some people have trouble and others dont
I had a 4.00 crank before but it did not hit the pan, just the windage tray, washers were the fix for that!
Chad
