Dart heads rocker info
Try contacting Tony Mamo, I vaguely remember him mentioning recently on here somewhere that he has a version of the Yella Terra ultralite that uses an M10 bolt, hopefully this helps.
Best wishes,
Jason.
Best wishes,
Jason.
They had some adjustable YT on them when I got them but sold them of not looking or thinking they had m10 threads so now I need to find something that's going to work or helicoil them and run standard rocker stuff.......
Also, have you explored punching out the bolt diameter of the stock rockers so an M10 will clear? You may need to use an allen bolt or something with a smaller head.
Why not pick up another set of the rockers like the ones that you sold?
If its hyd roller I would opt for the non adjustable version which has a lighter rocker arm.....just a beefier version of the common 6645 rockers essentially.
PM me and we can go from there!
Cheers,
Tony
