Metal in my oil... Thanks Comp Cams!
Old Aug 9, 2014 | 02:24 PM
  #41
JakeFusion's Avatar
Super Hulk Smash
Oh come on, Dave. You have a Vette. Obviously you can pay $450 for 16 bushings.
Old Aug 9, 2014 | 04:10 PM
  #42
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
For 200 bucks more you can have Yella Terra Platinums that will take a grand of spring pressure all day long. No thanks.
OP I hope all is well with the motor in the end. What do you plan to use now?
Old Aug 9, 2014 | 04:31 PM
  #43
Paul Bell's Avatar
That's MISTER MODERATOR
Right?? After all, Corvette owners get new cars when the ashtray fills up.
Old Aug 9, 2014 | 04:35 PM
  #44
99Bluz28's Avatar
Don't forget that you'll probably also need to more rocker arm clearance than the stock valve covers offer(even with the oil baffles removed with adj. rr ). So then you're look at least another $250 for new taller VCs .
Old Aug 10, 2014 | 06:27 AM
  #45
vettenuts's Avatar
That's why I don't smoke
Old Aug 31, 2014 | 08:25 AM
  #46
RADEoN's Avatar
Comp offered me "special pricing" on another trunion upgrade... I asked how much, and he never responded (this was 10 days ago).
I'm still trying to do enough research to get the rockers adjusted correctly. I have the UMI spacers (and boy are they nice), and I'm putting a ls2 valve covers in to use that PCV system. Probably going to be buying a second catch can to go along with that.
Old Aug 31, 2014 | 09:37 AM
  #47
RockinWs6's Avatar
I had a bad experience with comp long long time ago, I stay far away from their poor attitude and poor workmanship.
Old Sep 1, 2014 | 04:35 PM
  #48
RonSSNova's Avatar
So the root cause has not been established yet correct? You havent carefully cut a bearing apart to look?
