pushrod length. ...will I be ok...
Old Aug 7, 2014 | 08:27 AM
Gotit4cheap16's Avatar
Default pushrod length. ...will I be ok...
Just measured my pushrod length for my build and came up with 7.375. I already had 7.4 hardended chromolly rods and installed them and torqued
everything down and everythibg seemed good. Will I be good with 7.400 or should I order 7.375 just in case?
Old Aug 8, 2014 | 06:32 PM
Bump?
Old Aug 8, 2014 | 06:33 PM
redgto4u's Avatar
How much preload with the .375's?
Old Aug 8, 2014 | 07:48 PM
Its .050
Old Aug 8, 2014 | 08:29 PM
svede1212's Avatar
What lifters?
Old Aug 8, 2014 | 09:36 PM
redgto4u's Avatar
Most people set theirs up for .080 so the 7.4's ought to work good.
Old Aug 8, 2014 | 11:02 PM
Lifters are ls7 and cam is a btr stage 4.
Old Aug 13, 2014 | 12:33 AM
Bump....
Old Aug 13, 2014 | 02:42 AM
Always2Slow's Avatar
I would say the 7.375. Just because most people run their ls7 lifters at .080 doesn't mean it is correct for every application. Your .050 preload will turn into around .040 when its warm which is a good number for that cam.
Old Aug 13, 2014 | 06:03 PM
Thank you. I appreciate it.
Old Aug 13, 2014 | 09:12 PM
99Bluz28's Avatar
IMO, .075" pre-load with the LS7 lifters is fine so stick with the 7.4" PR's. If the valve train ends up being rather noisy with the .075" pre-load, then you might consider getting the 7.375 PR's.
