LQ4 build cam questions
The truck has a 2400 converter 3.73 gears 28 inch tires weighs 3600
Kooks 1-3/4 to 1-7/8 headers to a single 4 inch exhaust
The plan is to hone the bores, line hone the mains, 0 deck the block
Arp bolts in the rods and resize them
Molly rings and coated bearings
Ls2 chain
Ls7 lifters and new guides
Standard volume oil pump
Ls9 head gaskets
holley hi ram with a 90 mm tb
Looking for some ported heads in the classifieds
Is a cam with about 225 intake 230 exhaust duration on 114 too big for the converter
I cannot answer your question, but I will just toss this in here. I picked up an LS with a truck cam: http://www.summitracing.com/parts/cca-54-452-11
I have it for sale for cheap if you're interested!
Why does it have a 2400stall? Is it some cheap 12" unit like a Dacco that cost the shop $60 and they charged you $200?
I would do a real converter 3000+ stall 9.5" unit before doing those things to the motor.
It will likely drive ok with the low overlap and that stall but at this point I feel a decent stall would be a better performance mod than the cam. Been there made these mistakes myself and am telling you you are making a mistake.
I know Tick has a post on how LSA means nothing and I understand it and am not disagreeing with it but the only time I would look at 114 LSA for a modest street vehicle would be emissions or turbo. For NA I like a bit more overlap. I understand that when the cam gets big enough 114 can still mean a lot of overlap, you are looking at a reasonable amount of duration.
When I rebuild a engine, I always make sure everything is square and true, it just makes sense, everything lasts longer and works better
2400 converter because this truck gets me to work every day, rain ,sleet or snow
It is a circle d 300mm and it drives like stock ( important to me for the 4 months of driving with the blizzaks on snow covered roads)
I'm not looking to be the fastest truck in town, but since I'm spending this much time and money on this I am trying to achieve a good ballance of performance and drivability
I'd Look at the SDPC HT1 truck cam (214/218 111lsa+3, lift .569"/.562") it uses fairly mild lobes and it has a 36 IVC an -6* overlap so it'll runs smooth but still have a noticeable cam sound. IMO, it should also work good with that 2400 stall TC. The largest cam I'd use with that stall is a 216/224 114 +4 cam.
https://sdparts.com/details/scoggin-...er/cc54-st1-11
http://www.ws6project.com/user_stor/...oducts_id=5086
216/224 114lsa cam:
http://www.ws6project.com/user_stor/...oducts_id=4926
Here is a reply pulled from another thread on the same topic.
Cracked cap rods are not resized by the conventional method of grinding the parting lines to close up the vertical size then honing to spec. With a cracked cap rod you need bearings made over size so the rod bore can be honed to fit the over sized outside diameter bearing shells. In the case of the LS engines, that oversize is only .002" which is most likely going to be insufficient for a spun bearing rod housing bore to clean up. The .002" over sized bearings leave enough material to hone out of a rod housing bore to get a round bore (now .002" larger than a stock factory rod for use with these special bearings) to correct for distortion after installation of new rod bolts or for rods that are slightly out of round.
Steve
The g8 guys are using them with stock converters and making good power
Ported heads stock intake bolt-ons 440rwhp and running 11.80s
Will this cam work with cathedral heads?
Talked to circle d ,the lunati should work fine
I can't find any info on flow from the 1510 after .600, is it worth going that big(.625) or should I save the springs some wear and tear and stick around .600
If you really want less lift and less aggressive cam lobes the take a look at the Cam Motion Titan I (218/222 112lsa+4, lift .586"/.578", ramp rate is 55*)
http://www.mcssl.com/store/cammotion/the-titan1
So now I'm looking for some forged pistons, any suggestions?
Springs on my afr heads are good for .600, budget says I have to stick with them
So now I'm looking for a cam these springs can handle, in stock, can't wait for custom grind
Any cam gurus out there( Mamo, Martin, Pat g)
Want to get this cam ordered Monday
Titan 1 looks good
Any estimates on rwhp?
http://www.ws6project.com/user_stor/...oducts_id=4630
Titan 1 looks good
For a daily driver though, you may be better off with a $250 set of hypereutectic pistons, like from Speed Pro. I have never used them for an LS, but you may only be able to use them with a pressed pin connecting rod, so keep that in mind.
