Possible new ws6 owner with a few pics and questions!
I'm sure I'll be seeing you around.
Our local dealer wants $185 for wires. So its either the msd or the gmpp.. I'm guessing there isn't much of a difference , but I do see they have a MSD/NGK deal for $75 that looks pretty good..
Shift kit? Yes, no?
Trans cooler? I'm guessing the 15,000 btu is the most popular?
That is a link to the the tranny cooler I use and quit a few of others on here use, the bigger the better and I will probably be getting a bigger one eventually
I'd wait on a **** kit til' ALL maintenance is done
You'll be glad you did later.
fyi I can do plugs and wires installed for a lot less than the deal price ha. Although anyone will tell you #8 is a P.I.T.A
I'm doing plugs , wires, trans cooler , SLP lid and trans drain and fill, and a coolant flush at the moment.
I've seen many issues in the past with the SLP lid not fitting correctly or people using a heatgun to make it fit right. Is the ftp lid any better, or should I say worth $80 more? And I also noticed the size difference. There's the SLP, then ftp makes a 98, and 104mm lid.. I realize I don't need that now but, when I mod in the future, w heads , cam , etc and possibly think about getting a larger maf and throttle body, it seems it would be a waste to get the SLP lid for $100 if it won't fit that setup..
So basically just trying to future proof myself , and will get the ftp if it will be beneficial later down the road , especially with larger maf and tb, if not then I'll get the SLP.
.. I just wanted to ask the question about the lid in here to not clutter the forum with yet another lid question.Basically just wondering what to buy. The SLP or the ftp.. Only reason I ask is that if in the future when I do heads and cam, I would probably want to jump to a larger maf and TB, correct? And I didn't know if the SLP lid fit anything larger than stock. So I didn't wanna buy the SLP now to have it useless later .
I plan on having rpm speed ( ws6 store ) in Iowa doing all the tuning , so maybe I just need to talk to their tech guys and get a good setup to figure everything out
