Hardcore answer. direct injection head swap
Old Aug 11, 2014 | 01:42 AM
ChevyMonsterMouse's Avatar
Default Hardcore answer. direct injection head swap
any nays on these heads going on a 3rd gen block? like a bored out 6.0? if i could get these heads for only $225 a piece with injectors, would these 6.2 liter truck heads be worth the money? and what kind of piston would i need? Just a serious question before i consider giving up on LS3 heads... any one else thought of this before? what are the differences? i know the injectors are in the cylinder.. any oil or coolant roots that are different?
Old Aug 11, 2014 | 08:19 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Welcome to LS1tech!
We have a Gen V section for questions like this.
LT1 Gen V Head gasket:
LS3 Gen IV head gasket:
Old Aug 11, 2014 | 08:46 AM
JakeFusion's Avatar
Super Hulk Smash
The short answer is no.
Old Aug 11, 2014 | 10:36 AM
FirstGen F-Body's Avatar
theres alot more then just swapping heads theres a mechanical fuel pump driven by the cam, and theres probly 100 other things
Old Aug 11, 2014 | 01:14 PM
right.. i thought the mechanical fuel pump was driven from the serpentine. and i was thinking a fuel regulator might help with electric pumps then a mechanical one... custom made intake. sheet metal? just throwing some of that out there. run it with an ls1 harness.. budget friendly engine making 475+
Old Aug 11, 2014 | 02:19 PM
Paul Bell's Avatar
While I can certainly appreciate you're wanting to try something new, the fact that you thought the Gen V pump was driven off the front drive belt shows you haven't really studied this new engine very much.
Though the head gaskets look similer, I doubt the Gen V head would cleanly bolt up to a Gen III/IV block.
