comp short travel lifter preload
Ive gotten a few different answers about how much preload I need. Ive been told .003-.005, .020, and ive read .030 on here.......
What are you guys using?
The problem is if you have aluminum block and heads and you set them cold at .005 as soon as the engine heats up you will have about .005 lash. The block and heads grow about .010 so you would need at least .015 preload. So .020 to .03 would work well.
